Call parking and intercom
Discussion in '3CX Phone System - General' started by tjb1231, Jun 11, 2013.
  1. tjb1231
    May 15, 2012
    10
    I am having trouble setting up call parking and getting the intercom to work.
    3cx V11 with Aastra 6731i firmware 2.6.0.2019
    When a call comes in and you want to park it, we hit transfer then *01 to park it. It says call failed.
    I am interested in setting up BLF parking buttons. What is the syntax for that in the phone interface?
    Another issue we are having is
    When I assign Intercom and paging to the programmable keys nothing happens.
    We have a licensed version of 3cx.
    Here are some logs when I try to park a call
    11-Jun-2013 14:37:59.988 L:12.1[Extn] failed to reach ParkOrb:*0, reason Forbidden
    11-Jun-2013 14:37:59.988 Call to T:parkOrb:*0@[Dev:sip:*0@127.0.0.1:40000;rinstance=693b91c3e307bd6d] from L:12.1[Extn] failed, cause: Cause: 403 Forbidden/INVITE from 127.0.0.1:40000
    11-Jun-2013 14:37:59.988 [CM503003]: Call(C:12): Call to <sip:*01@10.0.1.11:5060> has failed; Cause: 403 Forbidden/INVITE from 127.0.0.1:40000
    11-Jun-2013 14:37:59.837 [CM503025]: Call(C:12): Calling T:parkOrb:*0@[Dev:sip:*0@127.0.0.1:40000;rinstance=693b91c3e307bd6d] for L:12.1[Extn]
    11-Jun-2013 14:37:59.787 [CM503027]: Call(C:12): From: Extn:9005 ("9005" <sip:9005@10.0.1.11:5060>) to T:parkOrb:*0@[Dev:sip:*0@127.0.0.1:40000;rinstance=693b91c3e307bd6d]
    11-Jun-2013 14:37:59.787 [CM503004]: Call(C:12): Route 1: from L:12.1[Extn] to T:parkOrb:*0@[Dev:sip:*0@127.0.0.1:40000;rinstance=693b91c3e307bd6d]
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Mileage varies, but I configured extensions 101-109 to forward to SP1-SP9 for a client.. then provisioned their 500S units with the shared parks so they (three receptionists) could see which parks were in play. It also helped them in the pre-11 days aka pre-ringback to see if a caller was in "Park Hell".
    The BLFs are "labeled" 101-109. The forward makes it easy to "pickup" the call from a shop floor handset after a page, for example.
    Beyond that.. couldn't say as far as that model.
    My first guess would be the dial plan. If the call makes it to the PBX, that's probably not the problem.
    BLF and Shared Parking works well.
    Can't add about your PSK config, either. We tend to run Cisco.
  3. tjb1231
    May 15, 2012
    10
    I like your idea of calls being forwarded to the SP's. However I do not see that option in the forwarding rules of the extension.
  4. ian.watts
    Apr 8, 2011
    532
    Reverse the direction.. forward 101 to SP1 under the Busy/Unregistered section.
    I stole that from a post two-ish years ago. ;)
  5. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    735
    113
    I would also upgrade the firmware on your Aastra phones. If you look at the template notes, they are designed for the v3.2 firmware.
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,977
    183
    Ian,
    I do not see, in v11 SP4, the ability to forward an extension to an SP. Unless I am not understanding your process.
  7. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    craig -
    I think that gs phones require the use of the "transfer" key to use the SP function; hence the reference to forward.
    Also, I finally played some with the T46. Provisioning took all of a couple of minutes manually as the look, feel and all of the web interface is typical Yealink. I like it.
  8. craigreilly
    Feb 1, 2012
    2,977
    183
    Larry,
    They mention in the thread setting up an extension to transfer to SP under under Busy/Not Available... But I do not see that the SP's are available in the Drop Down list.
  9. ian.watts
    Apr 8, 2011
    532
    Sorry for the delay.
    Indeed, if Phone is Busy, using an external number with SP6 as an example value.
  10. craigreilly
    Feb 1, 2012
    2,977
    183
    Does not work. Error message. It does appear to be valid input using MyPhone however.
    Note in v12 you can enter SP? in the External number field... but not in v11 SP4
