Call parking "Called number does not exist?
Discussion in 'Windows' started by ekoloda, Aug 21, 2012.
  1. ekoloda
    Aug 21, 2012
    9
    I have 3CX version 11 and Call parking and unparking works well through My Phone. I use Mitel SIP phones and call parking was working fine, but suddenly stopped.
    I have called parked on orbit 0 and when I hit *10 on Mitel - it says "Called number does not exist".
    I see parked call status fine, I also can use other Dial Codes on Mitel, except Call parking....
    10,767
    286
    Is there a 3CX log? Does the *10 even get through to 3CX, or is the phone 'intercepting" it for some reason? When did the behaviour change, was something to the set or 3CX done? Is it just one set, or a number? Do any other "hard" phones work as expected?
  3. ekoloda
    Aug 21, 2012
    9
    None of the hard phones work with *00 or *10 dial codes, only my phone works.
    Here is the log. I believe phone is trying to dial *10 number instead of using the dial code functionality.
    1-08-2012 14:39:47.732 Provisional response arrived for session 10712 of Leg L:60.2[Extn]
    21-08-2012 14:39:47.732 L:60.2[Extn] got Provisional Provisional Recv 180/INVITE from 192.168.7.72:59932 tid=e40697795a69724c Call-ID=MzlhMjk2NzUyZjdiODJhMDUzYTY2OTRlMDJlZGNiMzI.:
    SIP/2.0 180 Ringing
    Via: SIP/2.0/UDP 192.168.1.15:5060;branch=z9hG4bK-d8754z-e40697795a69724c-1---d8754z-;rport=5060
    Contact: <sip:6000@192.168.7.72:59932;rinstance=47296f439b82320f>
    To: <sip:6000@192.168.1.15:5060>;tag=e16e7407
    From: ":6474975023"<sip:6472961359@192.168.1.15:5060;nf=e>;tag=0f4cb450
    Call-ID: MzlhMjk2NzUyZjdiODJhMDUzYTY2OTRlMDJlZGNiMzI.
    CSeq: 1 INVITE
    User-Agent: 3CXPhone 6.0.20943.0
    Content-Length: 0
    21-08-2012 14:39:47.732 [CM505001]: Endpoint Extn:6000: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:6000@192.168.1.15:5060]
    21-08-2012 14:39:47.732 [CM503002]: Call(C:60): Alerting Extn:6000 by contact <sip:6000@192.168.7.72:59932>
    21-08-2012 14:39:47.731 UacSession 10712 has formed leg L:60.2[Extn]
    21-08-2012 14:39:47.669 Provisional response (malformed) arrived to Leg L:60.3[Extn]
    21-08-2012 14:39:47.669 L:60.3[Extn] got Provisional Provisional Recv 180/INVITE from 192.168.200.26:5060 tid=7866ef3063280256 Call-ID=M2ViNzQxZGE2ZTA4ZmM5NWYwYmJmMDgyZjhkYjRlMWM.:
    SIP/2.0 180 Ringing
    Via: SIP/2.0/UDP 192.168.1.15:5060;rport=5060;received=74.213.162.178;branch=z9hG4bK-d8754z-7866ef3063280256-1---d8754z-
    To: <sip:6000@192.168.1.15>;tag=12cc2096-3ac-4b8453ac
    From: ":6474975023"<sip:6472961359@192.168.1.15:5060;nf=e>;tag=d8501b68
    Call-ID: M2ViNzQxZGE2ZTA4ZmM5NWYwYmJmMDgyZjhkYjRlMWM.
    CSeq: 1 INVITE
    User-Agent: Mitel-5340-SIP-Phone 01.06.03.08 08000F279E44
    Allow-Events: talk, hold, conference
    Content-Length: 0
    21-08-2012 14:39:47.579 [CM503025]: Call(C:60): Calling T:Extn:6000@[Dev:sip:6000@192.168.7.72:59932;rinstance=47296f439b82320f,Dev:sip:6000@192.168.200.26:5060;transport=UDP]
    21-08-2012 14:39:47.579 Route to L:60.3[Extn] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=e21cc661540cb078 Call-ID=M2ViNzQxZGE2ZTA4ZmM5NWYwYmJmMDgyZjhkYjRlMWM.:
    INVITE sip:6000@192.168.200.26:5060;transport=UDP SIP/2.0
    Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-e21cc661540cb078-1---d8754z-;rport
    Max-Forwards: 70
    Contact: <sip:6472961359@192.168.1.15:5060>
    CSeq: 1 INVITE
    Alert-Info: <http://www.notused.invalidtld>;info=external
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Content-Type: application/sdp
    Supported: replaces
    Content-Length: 357
    v=0
    o=3cxPS 190303961088 304321921025 IN IP4 192.168.1.15
    s=3cxPS Audio call
    c=IN IP4 192.168.1.15
    t=0 0
    m=audio 7280 RTP/AVP 0 8 3 13 9 110 99 101
    a=rtpmap:0 PCMU/8000
    a=rtpmap:8 PCMA/8000
    a=rtpmap:3 GSM/8000
    a=rtpmap:13 CN/8000
    a=rtpmap:9 G722/8000
    a=rtpmap:110 iLBC/8000
    a=rtpmap:99 SPEEX/8000
    a=rtpmap:101 telephone-event/8000
    a=sendrecv
    21-08-2012 14:39:47.577 Added leg L:60.3[Extn]
    21-08-2012 14:39:47.577 [CM503025]: Call(C:60): Calling T:Extn:6000@[Dev:sip:6000@192.168.7.72:59932;rinstance=47296f439b82320f,Dev:sip:6000@192.168.200.26:5060;transport=UDP]
    21-08-2012 14:39:47.577 Route to L:60.2[Extn] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=fc6dec251c72a32d Call-ID=MzlhMjk2NzUyZjdiODJhMDUzYTY2OTRlMDJlZGNiMzI.:
    INVITE sip:6000@192.168.7.72:59932;rinstance=47296f439b82320f SIP/2.0
    Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-fc6dec251c72a32d-1---d8754z-;rport
    Max-Forwards: 70
    CSeq: 1 INVITE
    Supported: replaces
    Content-Length: 357
    v=0
    s=3cxPS Audio call
    t=0 0
    m=audio 7278 RTP/AVP 0 8 3 13 9 110 99 101
    a=rtpmap:3 GSM/8000
    a=rtpmap:13 CN/8000
    a=sendrecv
    21-08-2012 14:39:47.573 Added leg L:60.2[Extn]
    21-08-2012 14:39:47.536 [Flow] Call(C:60): making call from L:60.1[Line:10000<<6472961359] to T:Extn:6000@[Dev:sip:6000@192.168.7.72:59932;rinstance=47296f439b82320f,Dev:sip:6000@192.168.200.26:5060;transport=UDP]
    21-08-2012 14:39:47.536 [CM503027]: Call(C:60): From: Line:10000<<6472961359 (":6474975023" <sip:6472961359@192.168.1.15:5060>) to T:Extn:6000@[Dev:sip:6000@192.168.7.72:59932;rinstance=47296f439b82320f,Dev:sip:6000@192.168.200.26:5060;transport=UDP]
    21-08-2012 14:39:47.536 [CM503004]: Call(C:60): Route 1: T:Extn:6000@[Dev:sip:6000@192.168.7.72:59932;rinstance=47296f439b82320f,Dev:sip:6000@192.168.200.26:5060;transport=UDP]
    21-08-2012 14:39:47.536 [Flow] Endpoint Extn:6000 has no forwarding rule on reason 'All calls'
    21-08-2012 14:39:47.536 [Flow] Call(C:60): has built target endpoint: Extn:6000
    21-08-2012 14:39:47.535 [Flow] Target endpoint for 6000 is Extn:6000
  4. leejor
    10,767
    286
    I don't believe that Mitel sets have ever been officially supported by 3CX. I managed to get one model working a while back, but not well. the basic functions were OK.
    You haven't yet mentioned the particular model. That might help if someone recognizes a model that they have worked with.
    I'm wondering if the star codes are being intercepted as an internal function , by the set. I can only speculate that , perhaps something reset, and that is why it stopped working, unless you did something else with the set or at the 3CX end.
    You didn't really answer when I asked if you are using any other make of "hard" phone, just that, no hard phone is working. Am I to assume that they are all Mitels, or that you do have another make/model in use on the PBX, that also stopped working. If that is the case, then it would tend to point to a 3CX issue and not the set.
  5. ekoloda
    Aug 21, 2012
    9
    unfortunately I don't have any other hard phones either then Mitel. I tried *1 code on Mitel 5340 and 5224 models and both models don't work, but I swear it was working last week. I agree that it seems that phone doesn't recognize parking dial code and trying to dial the number. I am at the point where I will try to buy a Yearlink device and test it with it, but I have over 200 Mitel devices I want to re-use.
    I will appreciate any help in this direction.
  6. ekoloda
    Aug 21, 2012
    9
    I think it's working now. Thank you.
    I have reset settings on the phone to factory default.
  7. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,325
    253
    Glad you got it up and running. BTW: I have 60+ Yealinks (mostly T38's) in use - and so far so good. Solid devices. Good feature set. And Gigabit switch with POE.
