Call parking issue / suggestion
Discussion in '3CX Phone System - General' started by KilroyWasHere, Nov 22, 2011.
  1. KilroyWasHere
    Mar 24, 2011
    24
    Is there any way to cause the system to refuse to park a call at any given shared park location if that location already has a call parked there? If the same person parks 2 calls at the same SP location I don't see any way to answer a specific parked call. It would be helpful if the MyPhone app would use an unused SP location when parking a call. As it is, it always uses location 0 even if there is already a call parked there. Or am I missing something? Is it poosible to setup additional Shared Park extensions so that everyone could have their own? This would help.
  2. paul1
    Jan 14, 2010
    80
    You have some control over how MyPhone parks calls in the Settings tab under Preferences, Miscellaneous.
    There is a difference between Shared Parking and the regular parking orbits. There are 10 of each but only the regular parking orbits can have multiple calls parked.
