Call Parking Yealink T28
Discussion in '3CX Phone System - General' started by quayfour, Sep 8, 2011.
  1. quayfour
    Dec 1, 2009
    12
    I am using Yealink T28 phones.
    I would like to park incoming calls and display on a BLF so that the call can be picked up by another phone.
    (I really want to try to simulate key & Lamp)
    I don't seem to be able to get it to work - using phone provisioning or directly on the phone.
    BLF only gives the option of extensions
    custom speed dial also doesn't seem to work
    any thoughts
  2. willow
    willow Member
    Mar 1, 2011
    471
    it works quit fine on the yealinks you can use either phone provisioning or hard code it in the phone.
    on the phone go to phone then dss keys, then pick a key and select call Park for the type, value will need to be SP0,SP1,SP2.... account should be 1. Iuse T28's and T26's had have no issues.
  3. nbailey
    nbailey Member
    Jan 31, 2011
    359
    as willow said, the T28 provisioning works fine, BLf's work fine as well. You need to be sure it is setup correctly.
    be sure you have Enable semi-attend transfer = disabled first off. Second setup the BLF as needed and it will work no problems. We have guides at http://www.3cx.com/blog if you need more info on the T28.
    Thanks,
    Nate
  4. quayfour
    Dec 1, 2009
    12
    I have set up Call Park 0, 1, 2,3 on the first 4 BLFs but I cannot transfer the call to the parking bays.
    I have tried using the transfer button followed by the BLY key and also just pressing the BLF key
    I must be doing something wrong !
    Or am I missing another setting ?
  5. willow
    willow Member
    Mar 1, 2011
    471
    That should be all you hav to do? Do the buttons light up green when they are programmed?
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Call parking is not available in free version.
    In licensed version, if you assign Yealink BLF key to shared parking place (SPx), the button will be green in case if parking place is free, and red if there is a call.
    You don't need to initiate transfer to put call on a shared parking place, simply press corresponding BLF button (if it is green).
  7. quayfour
    Dec 1, 2009
    12
    I am using the paid version.
    10 sevice pack 2 Build 20401
    Yealink SIP-T28P
    Firmware 2.51.0.10
    Firmware 2.10.0.120
    The BLF keys do not light up by whatever method I try to park a call.
  8. quayfour
    Dec 1, 2009
    12
    Yealink SIP-T28P
    Firmware 2.51.0.10
    Firmware 2.10.0.120
  9. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Have you enabled the BLF button to be a Shared Parking button? within the 3CX Admin Console?
  10. willow
    willow Member
    Mar 1, 2011
    471
    i have seen this before when provisioning via the 3cx. you can either try defaulting the phone and removing the provisioning files from 3cx and redoing it, or you can hard code the buttons on the phone.
    The buttons should be green when the poark orbit is idle and red when there is a call parked there.
  11. quayfour
    Dec 1, 2009
    12
    I have hard coded the phone
    Call Park value *0 Line 1
    The button appears green.
    When the call is parked - the button does not go red and whilst the call is not hung up it cannot be retrieved.
  12. willow
    willow Member
    Mar 1, 2011
    471
    it is not *0 it is SP0 or SP1 or SP2 or SP3 and so on. the *0/*1 function is totally seperate from the SP functions
  13. nbailey
    nbailey Member
    Jan 31, 2011
    359
    your firmware is old. Latest version is 2.60.0.120. Also double check and be sure Enable Semi Attend Transfer is disabled.
    And try again. I have no problem with T28P and T26P with transfers and BLF's.
    Thanks,
    Nate
  14. 2way
    Jan 8, 2015
    Is it possible to program the shared parking key to flash when there is a call in park? instead of turning green or red?
    Carl
