Call Parking
Discussion in '3CX Phone System - General' started by abelaguilar, Jan 22, 2008.
  1. abelaguilar
    Nov 4, 2007
    94
    Hello all:
    I need to be able to park our calls. I'im using polycom 501 phones with patton 4114 gatweays and 3 pstn lines.
    I tried *00 and *10 function and does not work. Please help.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    transfer a call to *0n ('n' is a parking place. it is '0'-'9') is a "parking".
    make call to *1n[*EXTNUMBER] to get it from there ("n" parking place from *0 call. EXTNUMBER(optional) - extension from where call was transferred)
    Does it work?
    Regards
  3. abelaguilar
    Nov 4, 2007
    94
    Thanks i'll give this a try
    Why the heck does this have to be so dam complicated!!
  4. abelaguilar
    Nov 4, 2007
    94
    No does not work.
    I transfered then pressed *00
    then went to other phone and dial *10 and nothing happened.
  5. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    From lots of testing and emails with 3CX support you have to do a blind transfer to *00 to park the call. Not a regular transfer. That being said I can park from Linksys and Grandstream but not with my Polycom IP430 or 550 phones. It may be a phone config issue or they can't dial * codes with a transfer.
    if I get it working I will let you know.
  6. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    It is exactly the case for Polycom. You better re-define dial codes for Park/Unpark to be without '*' to work with polycom.
    For example:
    [DialCodes]
    Park = 78
    Unpark = 79
    Than, to park make an unattended transfer to 78N (N = 0..9, orbit number), Unpark - call to 79N or to 79N<Ext> where <Ext> is extension's number from which the call has been parked.
  7. abelaguilar
    Nov 4, 2007
    94
    Can dial codes be entered from the polycom web interface?
  8. archie
    3CX Support
    Aug 18, 2006
    1,299
    You can try, I suppose :) Never tried myself. Personally, I don't like polycom so I do not have any around. There're some in test lab though.
  9. abelaguilar
    Nov 4, 2007
    94
    I don't like polycoms either, but I have 6 laying around and they cost about 160.00 each.
