Call Pick Up issue
Discussion in '3CX Phone System - General' started by juanky, Jun 22, 2007.
  1. juanky
    May 14, 2007
    28
    I've noted when I pick up a call a huge delay occurs in the comunication...
    There isn't packet loss and the qualiy of sound is good... but there's till 10 seconds of delay since my interlocutor speaks and i get the voice...
    Any idea what's wrong???
  2. Anonymous
    Anonymous Guest
    Does this always occur or only after a while?
    Is it from the start of the call?
    What are there results directly after a reboot of your modem/router and the 3cx box?
  3. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Can you describe the call ? What phones are being used ?
    Is it a LAN call or is it incomming via gateway ? What about the server status page, are there any interesting log entries there ?
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    I also hit this issue. The voice around delay 7sec. It is same as juanky's case. There isn't packet loss and the quality of sound is good. Form system log there is no abnormal transition found. Then I drop the call and re-issue again. At this call, the delay should not found. Need not reboot the PBX or restart the services then back to normal. For voice delay call the media server seems need around 7 sec to build the RTP call.
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Could you please provide some more specific information about such calls. Is this issue reproducible, or it happens occasionally?
    Thanks,
    Stepan
  6. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    It happens occasionally. At system log it seem same as normal, nothing abnormal log appear.
    EXT 100 ---- NAT---INTERNET-----NAT----3CX PBX----NAT----INTERNET-----NAT----EXT 101
  7. 3CXsupport
    Aug 21, 2006
    193
    Ok,
    What are the ping times like ?
    EXT 100 --- 3CX PBX and 3cx PBX --- EXT 101 .
    Also, what is the bandwith usage of those 'pipelines'? are these net connections shared with other traffic (SMTP , HTTP) ?
  8. Anonymous
    Anonymous Guest
    Do not think it is a bandwidth (goodput) issue.
    question:
    When you have this happening, is the conversation part delayed. With this I mean, is it like:
    Hello ==== 7seconds ====== Hello
    or is it
    H===e====l===l===o
  9. juanky
    May 14, 2007
    28
    Hello again,
    Sorry for the delay to answer I was missing for a couple days ;-)
    It occurs to me almost allways...
    I don't think it is an banwidth issue because all the devices are in LAN ... and this issue doesn't occur if the call is transferred instead of picked up...
    Little Example:
    - Someone calls to my ISDN number ... it rings in the extension # 100 ... The "human" recepcionist attend the call and transfer the call to my extesion (# 101) ... All works fine
    The "human" recepcionist is out for lunch... so there's nobody in the extension # 100 ... so I pick up the call from my extension typing *10* (i tryied with *10*100 with the same results) and I caught the call ... Buts doesn't work fine ... there is a 7~10s deleay....
    The delay is
    Hello ==== 10 s ====== Hello
    There isn't packet loss... the quality is good... and , as I commented, all the voip devices are in the same LAN... and this does't occur if the call is transferred....
    Any idea???
    Thanks in advance.
  10. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Try to bind to media server the extension which does pick up.
  11. juanky
    May 14, 2007
    28
    The extension is already binded to Mediaserver...
  12. Anonymous
    Anonymous Guest
    To be honest, no idea really.
    So lets list the possibles:
    - Network, as you mentioned it sits all on the same network and the delay does not happen in when you transfer.
    - Codecs? Have all the devices G711U/A enabled?
    - Server/Computer the software is running on does it have enough grunt to do the job. Also I noticed that if you move 3cx to its own disk or a disk with low IO it works a lot better.
    - Defrag of the disk.
    The reason why I hint towards some HW issues is that your voice quality is good but the message does not come accross smooth there are delays. No idea why so we might aswell start at the bottom of elimination.
  13. archie
    3CX Support
    Aug 18, 2006
    1,299
    Than try to unbind it :)
  14. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    I will try to test this tomorrow first thing in the morning on the test network... I will come back to you with my conclusions..
  15. Costas3CX
    Jan 23, 2007
    217
    Did a few tests.. Just can't reproduce this...:(
  16. juanky
    May 14, 2007
    28
    Hello again,
    More clues...
    The delay issue only occurs when I pick up an external call... It works fine when i pick up internal calls...
    I can't unbind my extension from Mediaserver because if i do it when I pick up a call I can't hear to my interlocutor...
    I'll try to do more extensive tests this weekend...
    see you...
  17. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    maybe you can introduce Qos in your routers, letting voip traffic be the first.
    It might solve the delay problem if its router/network hardware related.
  18. juanky
    May 14, 2007
    28
    I think if it is a QoS releated issue... the delays allways occurs, even in transferred calls... , isn't it??
  19. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    i think your right, but since you tried all :D
  20. SY
    3CX Support
    Jan 26, 2007
    1,825
    few questions:
    1. If you simply answer call, is there any delays?
    2. Where from (VoIP provider, PSTN -VoIP gateway, some ISDP-SIP bridge etc.) are you receiving the call?
    3. Which kind of equipment are in use (software gateways, hardware etc)?
    It means who(what) delivers data to 3CX phone system?
    Logs can help to investigate a problem as well
    Thanks,
    Stepan
