call pickup *20* does not work on linksys spa
Discussion in 'Windows' started by rodster, Mar 4, 2010.
  1. rodster
    Aug 19, 2009
    13
    The call pickup feature *20* does not work on linksys media gateways (SPA 2102 and SPA 3102). According to the 3CX manual, pressing *20* should retrieve the call from any ringing extension. However, any phone connected to Linksys spa's generates a busy tone after pressing asterisk-two-zero (doesn't reach the last asterisk, immediately the busy tone is played). Seems that *20 migth be a reserved key in linksys? any help in making call pickup work in linksys spa's that's connected to 3CX? thanks
    11,073
    323
    Is it being blocked by the dialplan in the Linksys device?
    This question should be in the "General" forum as it's not about the 3CX VoIP Phone itself.
