Call pickup groups
Discussion in '3CX Phone System - General' started by Jimbo_, Jun 25, 2014.
  1. Jimbo_
    Jan 31, 2013
    18
    Is there a way to create call pickup groups? I understand you can do *20* but this picks up the first available call. *20*<extno> picks up call on the handset that's ringing but in order for this to work a department would have to know everyone extension number in that group. Is there a way to create "Department A" and anyone in that group can only pickup that groups calls so someone in "Department B" doesn't accidentally pickup a call from A etc?
    Jimbo
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Try go Settings / Advanced / Custom Parameters / search for parameter LIMIT_PICKUP_TO_GROUP, switch value to 1.
    Restart services.
  3. Jimbo_
    Jan 31, 2013
    18
    I worked this out in the end. In Settings > Global Options is a choice for "Limit Call Pickup to calls received in their extension group". I ticked this and made sure "Perform operations" was unchecked in the Default group but checked in the department extension groups.
    Cheers,
    James
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Perfect.
