call pickup not working ??
Discussion in '3CX Phone System - General' started by lotsu99, Dec 16, 2008.
  1. lotsu99
    Jan 1, 2008
    27
    i called:
    pstn > gateway > 3cx/DR > ext101
    and i couldn't pick up with another phone using *20* in 3cxV6.
    thanks
  2. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Please upgrade the PBX to version 7 if you are still on version 6. In version 6 there was a bug related to this where with certain phones under specific situations call pickup might not work.
    The dial codes remained the same - but they are 100% configurable from the interface - (In V7 the dial codes page is located under Settings\Advanced\Dial codes tab
    Note: The PBX must be licensed for Dial codes to be enabled
  3. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    * 20 * works under version 7
    The feature is completely feature complete when you specify *20* and the extension number/ring group no /queue no
    When you specify just *20* without an extension number after (wild *20*) it will work only from extensions to extensions.
    You cannot open pickup (*20* only) a call from a ringing member of a group.
    We are working to make this available soon. For now you have to specify *20*[RingGroupNumber]
