Call Pickup - Yealink T42 & T46
Discussion in '3CX Phone System - General' started by tomnorton, Sep 8, 2016.
  1. tomnorton
    Feb 23, 2015
    21
    I'm trying to get Call Pickup working.
    If 'Limit Call Pickup to calls received in their extension group' is disabled call pickup between 2 phones works fine. If this option is enabled then it fails to work despite the phones being in the same extension group.
    Is this a bug within V15?
    Also I am trying to configure the Call Pickup button on the Yealink Handset to dial the *20* number to pickup the call. Looking at the interface I should be able to specify this under 'features.pickup.group_pickup_enable' and 'features.pickup.group_pickup_code'.
    I have updated these fields within the template, however the Yealink ignores this when auto provisioning.
    Cheers
