Call Pickup
Discussion in '3CX Phone System - General' started by Dan_L, Feb 27, 2008.
  1. Dan_L
    Feb 26, 2008
    We have a 3cx phone systems using Snom 360 handsets, is it possible to pick up a call that is rining to another extension?
    Many thanks
    Dan
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hello sir
    Yes it is possible. To pickup a call from a ringing extension you just have to press *20*XXX where the XXX is the extension that is ringing.
    You can press just *20* if you want, but that just picks up the first of any ringing calls, not necessarily the extension that is ringing if more than 1 extensions are ringing at the same time.
    Please have in mind that *20* dialcode is configurable from the ini file under the dialcodes section.
    Also have in mind that if the call originates from a ring group, that you will not be able to pick it up with *20*XXX if XXX is the extension, and in that case you will need to pick it up with *20* or *20*YYY where YYY is the number of the ring group.
    Finally this feature is only a commercial version feature so its not available in the free version.
    Here is a comparison between the free and commercial version to be able to see the benefits of purchasing the software. http://www.3cx.com/phone-system/edition-comparison.html
    Regards
