Call Pickup
Discussion in '3CX Phone System - General' started by Michael Knutson, Aug 4, 2017.
  1. Michael Knutson
    Feb 20, 2017
    17
    Running V14.
    We know that we can use the *20*(extn#) to pick up a call. Or use *20* to pick up the first ringing call. We have a system with 8 locations with VPN from remote offices to the main office. The Main office would like to use just *20* and pick up first ringing call. Is there a way to do this just for that office and not pickup a call from the other offices?
    Thanks for the help.
    Michael
  2. V..
    V..
    Feb 14, 2017
    76
    29
    Hi Michael,
    You can acheive this by separating the offices into separate groups within the PBX.
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,332
    222
    As above, you probably need to tick 'Limit Call Pickup to calls received in their extension group' under Settings -> PABX
  4. Michael Knutson
    Feb 20, 2017
    17
    That sounds right. But correct me if I'm wrong. If I break all the offices into their own groups that would break the "Receptionists" from seeing all the active calls for the whole system?
  5. V..
    V..
    Feb 14, 2017
    76
    29
    Hi Michael,
    Not if the receptionists were included in each of the groups
