Call Q Softphone
Discussion in '3CX Phone System - General' started by Schrodz, May 12, 2017.
  1. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    I am currently setting up the 3cx system with the Call Q.
    I have created 2 Q's one Pre-booking and one sales. When I click on the Q button, it logs me into both Q's
    Is there a way that I can chose which Q I want to go into? Or am I assigned to both Q's
    Dan
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,749
    560
    In order to log in to one of the Q's you will need to use the explicit login/logout from the switchboard of the 3CX client. Please note that if you log your self out from the switchboard you will need to log back in from the switchboard as the Q button will only work for the Q that you did not login/logout using the switchboard.
    https://www.3cx.com/blog/docs/managing-queue-status/
