Solved Call Quality issue during Conference
Discussion in '3CX Phone System - General' started by techdummy, Oct 12, 2017.
  1. techdummy
    techdummy New Member
    Sep 22, 2017
    218
    9
    We have an issue with our Conference system.
    The issue is that the call quality is very poor, crackly, lots of distortion and we are unable to hear the client properly. They are unable to hear us too. We tried changing the devices but the issue is still there.
    Any ideas about what might be the possible causes? And how to go about troubleshooting this issue?
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @techdummy
    What phones are you using?Are they using the default templates? Have you ran the firewall checker with no errors??
    Thank you
  3. techdummy
    Sep 22, 2017
    218
    9
    Hello @IoannisM_3CX
    We are running 3CX client for windows and have configured it to use Jabra Speak 510 for conference.
    Firewall checker didnt show any errors.
  4. IoannisM_3CX
    Aug 10, 2017
    229
    18
    When you use only the 3CX client with no speakers or extra devices, does the issue occurs??
    techdummy likes this.
  5. John Ranger
    Jan 14, 2017
    23
    8
    Hi Techdummy.
    this sounds like you either have a Problem with the Jabra or that your Internet link is too slow to accomodate for all the calls which are used during the conference.
    Are these Voice conference calls or web conference calls? (I ask because this determines where the Audio mixing is done - in your 3CX or on the conf Servers of 3CX).
    Also you should consider/answer the question of IoannisM as this is relevant to distinguish between error of the Jabra oder the Internet link.
    With Kind regards,
    John
  6. techdummy
    Sep 22, 2017
    218
    9
    Thank you for the replies @IoannisM_3CX and @John Ranger
    Since I'm administering everything from remote location. It takes a little bit time if I want to check the hardware being used.
    I had a check on it with our VMware admin and a staff from the remote location, and it seems like the issue wasnt related to 3cx. Jabra is faulty but the main issue is that they haven't selected the right audio device while configuring 3CX client.
  7. techdummy
    Sep 22, 2017
    218
    9
    These are video conferencing calls, so the audio was being picked by the webcam it seems.
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
    Glad to hear you found the issue and thank you for updating the post
