Call Queue Count of Callers on Hold
Discussion in 'Call Flow Designer' started by Pat Huesers, Sep 7, 2017.
  1. Pat Huesers
    Sep 7, 2017
    How can I use the 3CX API to query the amount of callers that are in a call queue? It looked like this was it, but it does not compile.
    public int QueueCalls(string queueNumber)
    Queue[] queues = PhoneSystem.Root.GetQueues();
    foreach (Queue queue in queues)
    if (queue.Number == queueNumber)
    ActiveConnection[] conns = queue.GetActiveConnections();
    return conns.length();
    return 0;
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
    Hi @Pat Huesers,
    Your code looks fine, but it seems you're missing the if braces. Your code should be:
    Code:
    return 0;
    But also, instead of iterating the queues, you can just get the DN by invoking:
    Code:
    Queue queue = (Queue) PhoneSystem.Root.GetDNByNumber(queueNumber);
    Then, your code would be much simpler:
    Code:
    Kind regards.
  3. Pat Huesers
    Sep 7, 2017
    Ernesto-
    Thanks for the help and the code. I am using this code below you gave me, but it seems to be returning the qty of Agents logged into the queue, not the qty of callers that are holding in the queue. What is the correct way to get that information?
    Code:
