Call queue Escalation Popup in CTI Client
Discussion in 'Ideas' started by wagner@netplanet.at, May 13, 2016.
  1. wagner@netplanet.at
    Dec 21, 2013
    it is possible to send an eMail if an caller is to long in an quee. It would be greate to make a POPUP in the 3CX Client for the Queemanager if the SLA is Breached.
    kind regards
