Call Queue - Music on Hold not playing when assigned a Playlist
Michelle Dinh
Forum User
In Settings > Music on Hold > Playlists, I created a playlist with 3 different .WAV files.
On a Call Queue, I updated the music on hold setting to my playlist, but it seems like it's still playing the GENERAL MOH under settings > Music on Hold
How do I fix it?
Hi Michelle,
So, is there a problem? you say it "seems" but is it? FYI: Captivate has a fix for having to upload multiple files. We have a script that downloads daily and saves into the correct place so daily content changes are no longer a problem..
Not sure if it is the same problem. This week I was trying to change the default music on hold. Not any queue music on hold but the default one in Settings->Music on Hold.
It didn't work until I edited the trunk and disable in its Options configuration page Supports Re-invite
Hi Michelle,
Yes, there is an issue. On a specific queue, the playlist that I assigned to the music on hold is not playing.
Hi Michelle,
Try setting the single .WAV file as music on hold without using the playlist feature - Does this part work, is the music playing?
If yes please check your 3cx services and look for the service called "3CX PhoneSystem 01 AudioProvider" if its not there, i suppose you did an automatically 3cx update, this way the service is not implemented and would require an backup-> reinstallation.
Reactions: YiannisH_3CX
Get 3CX - Absolutely Free!
3CX
