Call Queue not registered
Discussion in '3CX Phone System - General' started by CTJackal, Apr 29, 2009.
  1. CTJackal
    Apr 29, 2009
    Sorry to be a bit of a noob, but I've hit a problem I can't sort out.
    I created a call queue (Extn 800) and added a single extension as a member. The extension can log in and out of the queue, but the system log tells me the extension 800 is unregistered when it receives an incoming call:
    16:38:48.890 [CM503015]: Call(30): Attempt to reach <sip:800@192.168.200.110:5060> failed. Reason: Not Registered
    Any ideas anyone?
    Carlos
  2. CTJackal
    Apr 29, 2009
    Hi, I manged to find the answer to this. According to the services status, the digital receptionist was running, but checking the services under windows, the service was stopping (though not actually stopped!). Needed a reboot, but problem solved.
    Carlos.
  3. Angus
    May 12, 2009
    After entering the tag, the system needed to be rebooted to enter the tag. So, please do that and the system will follow your message then.
