Call Queues Displayed on Yealink T48s
Discussion in '3CX Phone System - General' started by ntnetzeband, Aug 9, 2016.
  1. ntnetzeband
    Jul 30, 2016
    65
    5
    We currently have Yealink T48s and T49s deployed at our site. Our call queues are displayed on the T49s screens when incoming calls are made to that queue but not on the T48s, it's just the Caller ID.
    So the screen displays the following:
    T48 - Caller ID
    T49 - Call Queue: Caller ID
    Does anyone know how to get the call queue to display on the T48s or is it just a matter of screen size not being large enough.
    Any help would be greatly appreciated :D
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    432
    67
    If the CID phone number of the calling party matches a phone number in your company phone book then the Yealink T46/T48 phones will only show the text from the company phone book and not the Group Name: CID Name.
    Delete the entry from your phone book, update the phone book on the phone and try again and it should display properly.
  3. ntnetzeband
    Jul 30, 2016
    65
    5
    I think that I may have not been as clear for the current needs. We use internal call queues as well as external call queues. The internal call queues are for different departments so that we can have people logged out when different departments are closed because some departments run at different times.
    We have different people in different internal queues so we want them to be able to differentiate which group is trying to be contacted. We want to have the call queue label which identifies that group.
    So the internal queues are being called by internal extensions are in the phonebook technically I think since they are registered in the system.
  4. CentrexJ
    CentrexJ Member
    May 5, 2009
    432
    67
    Yes that would trigger the Yealink behavior as well. I'm not sure how to turn that off other than removing the directory from the phone if it isn't necessary. Put in an email to yealink there may be a setting to turn off the caller id name override on match.
  5. ntnetzeband
    Jul 30, 2016
    65
    5
    Thank you for your help. I will contact them.
  6. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,338
    76
    I believe the setting you are looking for in the Yealink interface is under Directory -> Remote Phone Book, and here switch the "Incoming/Outgoing Call Lookup" to Disabled.
