Call recording - changing file location
Discussion in '3CX Phone System - General' started by haywardi, Mar 10, 2011.
  1. haywardi
    Feb 27, 2011
    84
    I've been looking around the 3CX site and documentation and so far, haven't been able to find an answer to this question.
    I would like to turn call recording on for ALL calls. However, the default location for the resulting WAV file is a hidden folder on my c: drive.
    This isn't really a solution for me as I run very small solid state c: drives and would like to move the location to a raid 5 multi terrabyte location....
    But how do I change the location?
    All help gratefully received.
    Iain
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    There is a setting under Settings > General > Global Options to change the recording path.
  3. haywardi
    Feb 27, 2011
    84
    Thank you
    Iain
