Call Recording: Directory Change Possible?
Discussion in '3CX Phone System - General' started by simonbresolve, Oct 17, 2008.
  1. simonbresolve
    Oct 15, 2008
    I was wondering if it is possible to change the directory that the call recordings are sent to. Any help greatful!
    Thanks,
