Call Recording on V7
Discussion in '3CX Phone System - General' started by Jordy, Aug 13, 2009.
  1. Jordy
    Aug 13, 2009
    is it posible to recording a call by pressing a key combo on or Linksys SPA921?
    And can you change the recording path in 3cx v7?
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    After doing a quick look around I can't find a feature code to enable recording, however I believe the feature is supported on the SNOM phones. If someone could provide some info on how the snom phone passes the bits to 3cx, I'm sure we could transfer that to your linksys phone.
    I don't think you can change the recording path tho.
  3. tpinnovations
    Jul 30, 2009
    296
    Do you know what bit or string is passed from the "special button" to 3CX to enable & disable recording?
