Call recording when dialing in 3cx & making outgoing call
Discussion in '3CX Phone System - General' started by kolagola, Dec 21, 2010.
  1. kolagola
    Sep 30, 2010
    9
    I have been trying to call my 3cx phone number, then dial 999 access voice mail and enter extension no & pin no. & then press 9 for more options and press 3 for making external call.
    I fail to understand that when making this call I am using that particular extension then why does the call not get recorded for that extension in this particular scenario.
    If i dial out straight or receive any incoming call then it records the calls fine.
    Please provide help.................
    Thanks,
    Kola
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Re: Call recording when dialing in 3cx & making outgoing cal
    The call is being routed trough the extension it is not being dialed from the extension, so in actual fact the extension is never involved, it is a conversation between the 2 external entities.
    You could post a feature request on ideas.3cx.com
