Call Recording
Discussion in '3CX Phone System - General' started by inet777, Jul 16, 2009.
  1. inet777
    Jul 15, 2009
    6
    Hi, is there any way to record external calls going through Voice Mail Menu?
    I can record calls made to an extension.
    But when a caller calls into the voice mail, presses 9 for more options and then presses 3 to dial an extension, the calls are not recorded. Anyway to record these calls?
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello,
    do you have test option which said "record all of call" from this extension ?
    if not today there is no mean to record call with physical phone, since voice mail, since soft phone it's possible.
    post your request to request feature.
