Call Recording?
Discussion in '3CX Phone System - General' started by zone97, Jul 21, 2011.
  1. zone97
    Dec 12, 2010
    11
    I have been trying to get call recording to work. The logs indicate a recording has started but the location shows this.
    z:\recordings\unknown
    No file name?
    I set the global options to record to the z:\recordings\ folder, but nothing ever shows up in there even though all the extensions are set to record. Anyone know what needs to be done to get recording to work?
    Update: If i move the record location to the local drive c:\recordings\ it works. How can I get this to work on a mapped drive or use \\server\location ect.
    Update2: After more research, seems as though 3cx wont let you record to a nas or mapped location. Bummer.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    could you check the folder permissions and ensure "everyone" has full access
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    The problem is the bandwidth that recording calls takes up. The best thing I have found is to record to a local drive and then have a batch file that runs on a regular basis to move them to a NAS or network share.
  4. willow
    willow Member
    Mar 1, 2011
    471
    using the scheduled batch file to move the files is the way to go. recording across the network uses to much bandwidth and resources.
