call recording
Discussion in 'Windows' started by stash, Jun 6, 2012.
  1. stash
    stash New Member
    Feb 23, 2012
    213
    Does anyone know if all the ip phone has the capability of call recording? i saw on yealink you need to do a programmable keys for you to be able to have a call recording button on it. anyone tried on other brand of IP Phone?
    Thanks,
    STASH
    11,293
    361
    The phone itself is not doing the recording but merely activating the feature on 3CX.
    http://www.3cx.com/blog/voip-howto/call-recording-with-aastra-5i-ip-phone/
  3. stash
    stash New Member
    Feb 23, 2012
    213
    Sir Leejor,
    I already read this. is the step applicable on all IP phone?
    Thanks,
    STASH
  4. leejor
    11,293
    361
    It would appear to (first off) require a set with a programmable XML softkey. That may limit your set selection, if you require this feature.
    You may just want to go with one of the sets where this procedure has been documented.
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    The T26 and T28 Yealinks should be able to do it. The T3x series we expect a firmware later this month with XML Support.
  6. stash
    stash New Member
    Feb 23, 2012
    213
    Sir leejor,
    Can you provide me where to get that programmable XML softkey? or is this something that i should create? if so can you provide me a copy of a template?
    Thanks,
    STASH
