call recording
Discussion in 'Windows' started by patb, Jun 23, 2012.
  1. patb
    Jun 23, 2012
    when using a 3CX phone on windows computer where does the recorded file get saved to if you record the call??
  2. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    On my system it is here:
    C:\Documents and Settings\All Users\Application Data\3CX\Data\Recordings
