Call recording
Discussion in '3CX Phone System - General' started by bluefox8080, Dec 10, 2007.
  1. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    I see that Version 5 does have a call recording feature. Where does one enable or disable it?
  2. novastar
    Jul 16, 2007
    15
    Currently this only works with a SNOM IP-phone. When you press a function key with the label F_REC than 3CX will begin recording directly and saves the conversation in \3CX PhoneSystem\Data\Recordings. I've tested this function with success.
  3. Mori
    Mori New Member
    Mar 23, 2007
    223
    Hi bluefox8080.
    Have a look at
    http://www.3cx.com/forums/categories-1/3cx-phone-system-general-1/call-recording-for-3cx-3274/
  4. bluefox8080
    Oct 28, 2007
    181
    That does not help me.
    Version 5 does apparently have call recording according to the site:
    http://www.3cx.com/phone-system/edition-comparison.html
    Unified Communications & Mobility Features
    Public SIP ID for extensions
    Supports Exchange 2007 UM
    Branch Office Integration
    Sends voice mail via email
    Fax
    3CX bridge: connect branch offices
    Call recording
    Remote configuration of extension options
    I don't care if it is Legal or not. Asterisk supports it by default and in South Africa it is legal if you announce it to the caller.
  5. Mori
    Mori New Member
    Mar 23, 2007
    223
    The point was not regarding legal or not.
    I quote two posts from other thread:
    With answer
    As novastar says its a user feature and currently works Snom, and the new 3CX Client if you dont want to use 3rd party recording.
    'All over' call recording is considered for future builds.
    Hope this clearify things.
  6. bluefox8080
    Oct 28, 2007
    181
    So, There is not Centralized option (under the Web interface) to record all the calls?
  7. Mori
    Mori New Member
    Mar 23, 2007
    223
    Nope, not yet.
  8. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    as said that it considered so it will be available in future build better have little patients as well.
