Call Recording
Discussion in '3CX Phone System - General' started by k2knet, Jun 20, 2013.
  1. k2knet
    Jun 20, 2013
    Hi all :)
    According to our company policy we must record All calls . is 3cx support automated calls recording ?
    How !?
    Thanks .
  2. AmishS
    Jun 20, 2013
    You can set calls to be recorded by enabling the Record All Calls flag for each extension. The setting can be found in the extension settings under Other->Extension options. The calls will be recorded to the location set in the General Settings->Global Options->Recording Path if I'm not mistaken.
    Below is a link to a Call Recording Manager from a third party.
    http://www.3cx.com/blog/news/3cx-recording-manager/
    Hope this helps!
    Kind regards,
    Amish.
