Call Recording
Discussion in 'Ideas' started by alternate, Feb 24, 2016.
Call Recording 5 5 1votes
5/5, 1 vote
  1. alternate
    Jul 29, 2011
    Presently the 3CX Pro License supports All Call recordings. However many customers would like the ability to record only the queue calls, but not the personal calls. Is the only way around this to give the customer 2 extensions?
  2. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    In 3CX, the call recording is by extension. If it is turned on for an extension - it would be for all calls involving that extension. This might be a disincentive for employees making personal calls on company time?
    Allen
