call recording
Discussion in '3CX Phone System - General' started by Anonymous, Dec 11, 2006.
  1. Anonymous
    Anonymous Guest
    does anyone know whether 3cx can recording calls,
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,875
    171
    Not at present. Although this feature is planned for future versions
  3. Watashi_FR
    Dec 5, 2006
    63
    If you are using a softphone that supports call recording you can record your calls. XLite supports recording, for example.
  4. Nick Galea
    Jun 6, 2006
    1,875
    171
    Thanks, watashi. Excellent tip :)
    Another one that allows you to do that is the Gizmo phone
    http://www.gizmoproject.com/
  5. Anonymous
    Anonymous Guest
    thanks all, i'm using xlite but it does not have automatic recording as the user has to click a recording button.
    also i'm having trouble to register a voip on 3cx, the provider are using port 1710, any suggestings, thanks
  6. Watashi_FR
    Dec 5, 2006
    63
    You can supply the port when you add a new line (or change it for an existing one). Change the value in the Proxy Port (default is 5060) to 1710 and make sure that if you use a firewall it should allow traffic through this port (1710).
