Call Recording
Discussion in 'Windows' started by Kevin Horsley, Aug 18, 2017.
  1. Kevin Horsley
    Aug 18, 2017
    With the latest update the Record Call button turns blue alerting the user to the fact the call is being recorded but also allowing them to end the recording if they want to. Is there anyway of stopping them from doing this?
  2. Luis Santos
    Jul 17, 2017
    18
    I have just tested this, Thanks Kevin for bringing it up to my attention, this needs to be looked at ASAP! our agents should not have control over their phone recordings!
  3. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello Kevin Horsley
    Luis Santos,
    I would like to inform you that this feature is not recently added, it is a future that existed in previous versions too having the same functions as now but with the exception that the recording button was not turning blue.
    Nevertheless if you find that this is something that has to be changed or altered somehow, you could post your suggestion in the Ideas section of the forum in order to be up-voted by other members and evaluated by the appropriate department.
    You can find it here: Ideas
    Thank you
  4. Andrew Oliver
    Aug 31, 2017
    We have a 3CX pro system and have all of the calls recording, this is used for training. As payments are to be taken over the phones, we need the ability to basically pause the recording, and re start at a later time, once PCI data is not being passed.
    Can this feature be used in this way, is there a simple way to set up a key on the Yealink T42G to pause the recordings.
    Any help appreciated.
