Call recordings file name.
Discussion in '3CX Phone System - General' started by DKar, Jun 15, 2009.
  1. DKar
    May 29, 2009
    Hi.
    What information is used to build call recordings file name?
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello,
    user and date.
  3. DKar
    May 29, 2009
    For example I have following wav file
    [Name]_Number1-Number2_20090424122558(358).wav
    1. Why does Number1 depend on callhistory3.callerid in one case, in another case on callhistory3.from_no.
    2. Why does Number2 depend on callhistory3.to_no in one case, in other cases on callhistory3.dialednumber, calldetails.dest_dn or calldetails.dest_num.
    3. Why does 20090424122558 depend on callhistory3.answertime in one case, in another case on calldetails.answertime.
    4. What does mean (358)?
