Call rejection by 3CX server when configure PSTN trunk
Discussion in '3CX Phone System - General' started by yogesh02ec, Mar 28, 2013.
  1. yogesh02ec
    Mar 28, 2013
    I have installed free 3CX server version V11.0.28976.849.
    I created one of the PSTN trunk with registration require option as "Do not require".
    Now when i send call from gateway with calling party CLI in SIP id field to 3CX server, server sends 404 user not found message?
    How can i configure PSTN trunk to dispaly calling party number on server extension?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    There are indeed some providers that actually do not require registration in order for the calls to be made; however I do not think this to be true for the gateways. Nevertheless, while it may not be required, the fact of the matter is that 3CX does require it as registration is the only way for the system to know if the device is present and the associated paths available. By this I mean that the routes created when you installed the gateway must be showing green in the status indicator.
    You did not mention the make/model of gateway and if the status lights show as the paths being registered. In most cases with PSTN, caller-id is normally handled by the carrier but not always. I confess I am confused as to what you want to do versus the title of the post and your description of issues.
    When you say " when I send a call from gateway", this implies to me that you have dialed an external number that is on the PSTN side; yet you then ask about how to display the callerID on the extension.
    Can you clarify and possibly post a log along with the gateway info asked for earlier?
