Call Report on WebRTC calls
Discussion in 'Ideas' started by 12494, Dec 6, 2015.
  1. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    Allow use of "WebRTC" as a search value for Call Source when generating a Call Report to create a report of calls generated by WebRTC. Presently when keying in WebRTC for number contains we are told that field must contain only numbers.
    Allen
  2. Rick Nay
    Oct 23, 2015
    Similarly, it would be nice to be able to filter for "VMail" to help identify calls that are delivered to voicemail. In v14, we are unable to search for a destination of the voicemail extension (such as 999) to find the number of calls delivered to voicemail.
