Call Report
Discussion in '3CX Phone System - General' started by Wicom, Feb 4, 2009.
  1. Wicom
    Jul 8, 2008
    Hello Boys
    you can make the 3CX PBX can export to a text file of the report called?
    The report file must be exported to a shared folder on the network automatically.
  2. Hammertime
    Feb 5, 2009
    10
    Hey
    Is it possible to extract the list to excel or notepad after i get the data from the call reporter utillity??
  3. Minik
    Oct 9, 2008
    6
    No direct export. You can select, copy and paste to an excel sheet.
    Minik
