Call Reporter always hangs up
Discussion in '3CX Phone System - General' started by KenC, Sep 20, 2012.
  1. KenC
    Mar 29, 2012
    85
    Maybe I'm not waiting long enough but I figured with only 10 calls during the interval requested 5 minutes should be long enough. I've never used the report generator, so these have been test runs. Once I request the report the only way to cancel the request is through windows system manager. No reports.
    How do I troubleshoot?
    thanks
    Ken Cohen
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    i have the same situation, untill now reporter was working well, from today it just hangs up (3cx v10)
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    What web browser are you using? I do know einternet explorer causes delsays in the web gui and other tools for 3cx. I use Firefox and have never had any of those issues.
  4. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    I am having this issue on v10, via call reporter app. BTW abby is installed with v10
  5. KenC
    Mar 29, 2012
    85
    Uninstalled v. 10 and installed v. 11. No problem running Reporter now.
    Thanks to all.
