Call Reporter Filter
Discussion in '3CX Phone System - General' started by tpinnovations, Jan 28, 2010.
  1. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    I need to produce a report that shows all calls from a couple of area codes + all calls that had their callid withheld. What syntax should I be using to produce that report?
  2. StaffKB
    Jan 5, 2010
    97
    What you can do is generate separate reports with the wildcard "%" for example.. you would like to filter calls from UK then in the source you would Write 0044% where the % is a wildcard stating all calls starting with 0044 ending in WHATEVER... However you would have to create a separate report for each of the area codes you require....
    Regards,
