Call reporter - report by DID / DDI
Discussion in '3CX Phone System - General' started by cartwrightm, Aug 20, 2012.
  1. cartwrightm
    Jul 10, 2012
    8
    I have 20 different DID's (individual telephone numbers) coming in, and want to produce a simple report which shows the number of calls received daily for each number. All numbers go to a separate Digital Receptionist, and are then routed to one of two Queues.
    I am using new v11 web reports and have Call Centre Module.
    Sounds simple so I'm sure I'm missing something - can someone help?
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    If every number is going to a separate DR that it's simple. Use Call Statistic reports->Call Logs. Filter Source as External and Destination as Number start with = your DR number.
    I hope this helped.
  3. cartwrightm
    Jul 10, 2012
    8
    Hi Dan,
    Thanks for the reply. Every number does go to a separate DR (which then goes to a Call Queue and then an Extension). However, when I run the report I don't see the calls.
    If I try and run the report for all calls (not filtering at all) this is what I see:
    The report seems to be picking up the Queue, and the Extension (e.g. 820-123), but not the DR. All calls in definitely go to a DR.
    Hope you can help!
    Molly
  4. danhriscanu
    Nov 29, 2011
    232
    Unfortunately you cannot extract that information from your actual configuration. A call which arrive to a queue is treated strictly as a queue call and you can extract information about them from Call center reports.
