Call Reporter Utility
Discussion in '3CX Phone System - General' started by abouelric, Jan 17, 2009.
  1. abouelric
    Jan 17, 2009
    32
    I have the latest 3cx V7. when using the call reporter, the data shows up but the "Source" field is always empty.
    Any idea how to solve this issue?
    Ricardo
  2. Stiderx
    Jun 30, 2008
    16
    Hi Ricardo
    If you refer to 3cx.com/support/call-history-updater.html - (this link is no longer available) this should solve your problem. It worked for me.
    #2 Stiderx, Jan 17, 2009
  3. abouelric
    Jan 17, 2009
    32
    Thank you for your reply
    using the callhistory updator is not the issue, after using this tool, the data in the "source" column is always blank/empty, whereas there is data in other columns. Moreover if I try to filter the data to a specific extension example (extension 100) it does not return any rows at all. If I filter using the "destination" column or any other column the call reporter returns data but the "source" column is always blank.
  4. abouelric
    Jan 17, 2009
    32
    Check the below picture that shows the source column empty
  5. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    My client has the same problem. Cannot find solution.
  6. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    When running the Call History updater, run this from the command from as 'callhistoryupdater.exe -h3' and see if the most recently imported logs have this entry to reflect the source field.
  7. knarf
    Jan 19, 2009
    Hi guys,
    I have also the same problem.
    Here is my log after executing 'callhistoryupdater.exe -h3'
    Checking call logs..
    SELECT value,kind FROM dnallocation
    select max(idcallhistory3) from callhistory3;
    insert into callhistory3 (idcallhistory3, callid, duration, starttime,answertime,endtime, from_no, to_no, group_no, line_no, is_answ, is_fail, is_compl, is_fromoutside, CallerID, DialedNumber, lastCallerID, lastDialedNumber, mediaType ) values (4,'326b9a0b065a332b','00:00:08.2330000','2009/1/19 1:42:55 PM','2009/1/19 1:43:04 PM','2009/1/19 1:43:13 PM','100','0223660843','','10000',True,False,True,False,'100','0223660843','100','0223660843',1);
    insert into CallDetails (IdCallHistory2, DetailNum, ParentDetailNum, Dest_num, StartTime,Dur, AnswerTime, Status, Is_Compl, SpecDstType, is_tooutside) values (4,1,0,'0223660843','2009/1/19 1:42:55 PM','00:00:18.0450000','2009/1/19 1:43:04 PM',6,True,0,True);
    insert into CallDetails (IdCallHistory2, DetailNum, ParentDetailNum, Dest_num, StartTime,Dur, AnswerTime, Status, Is_Compl, SpecDstType, is_tooutside) values (4,2,1,'10000','2009/1/19 1:42:55 PM','00:00:17.8880000','2009/1/19 1:43:04 PM',6,True,0,True);
    Processing and updating DB
  8. abouelric
    Jan 17, 2009
    32
    I don't know if the one i rounded shows the missing source number.
    here you go
    thanks in advance
    Ricardo
  9. abouelric
    Jan 17, 2009
    32
    Apparently i am not the only one who is facing this issue, and i think it is bug in 3cx because i did a clean installation on a seperate server and still the logs are missing the source number.
  10. ice
    ice New Member
    Jun 11, 2008
    108
    I also received complaint from client.
    Previous ver.7 have no this issue.
  11. igor.snezhko
    Jan 7, 2008
    668
    7
    Today I recommended to my client to swith back on previous build and all works fine.
  12. NRG
    NRG
    Dec 24, 2008
    31
    Got the empty source field as well.
  13. Minik
    Oct 9, 2008
    6
    Support has trasmitted to developpement. Just have to wait...
    Minik
  14. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Yes this is a problem - this arises because there are new Call History records that the V6 Call reporter does not understand.
    We are currently testing the new version of the Callhistory Updater and the new Call reporter. This will be for the 7.1 release - approx Mid next month.
    The -H3 argument is a new argument and You will not benefit from this data using the old call Reporter. But You will definitely benefit from these details and much more when the new Reporter together with the improved history will be launched.
    This explains why you see the details in Version 6 and some are skipped in V7. Because the Version 6 of the call reporter was optimized and designed for the Version 6 of the 3cx phonesystem and not for Version 7.
    I suggest that you all keep your callHistory.log file intact making backups of it regularly in the database and also keeping the callhistory.log files available.
  15. NRG
    NRG
    Dec 24, 2008
    31
    Just checking to see how the fix is progressing.
  16. abouelric
    Jan 17, 2009
    32
    Any updates when this issue will be solved?
  17. William400
    Aug 21, 2006
    1,005
    This shall be addressed in V7.1 and its reporter. This should be expected in a few weeks time.
  18. bulldozzer
    Dec 25, 2008
    12
    I can not wait for this fix as well
  19. abouelric
    Jan 17, 2009
    32
    finally the the 7.1 is released.
    but how do we backup and restore the call logs of ver 7.0 to ver 7.1?
    I still have the callHistory log file of version 7.0, so does anyone have any idea how to import the data to version 7.1?
  20. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    open command prompt
    cd:/programfiles/3CXPhonesystem/bin
    calllogsbackup.exe -backup c:/[pathforfile]
    calllogs will backup all the call logs and put them in c:/pathforfile
    Then after you install 7.1 do the same thing but this time you need to restore right - so type
    open command prompt
    calllogsbackup.exe -restore c:/[pathforfile] - the same path where the call logs were actually backed up previously.
