Call Reports based on SIP Trunk,
Discussion in 'Ideas' started by aslampa, Dec 22, 2017.
Call Reports based on SIP Trunk, 5 5 7votes
5/5, 7 votes
  1. aslampa
    Mar 18, 2016
    45
    We have multiple SIP Trunks/VOIP gateway connection with our 3CX phone system. We noticed that there is missing of feature in 3CX to generate a Call Report based on SIP trunk/VOIP gateway like we get report of Queue statistics, also it is pretty hard to filter out the calls made through particular SIP trunks/VOIP Gateway.
    Also would like to have Monthly Wise Summery Report for incoming and out going calls, this help to compare the last couple of months calls trends.
    Also the we are not able to pull the monthly report completely if the records are more than 10,000 columns. If you could address this , it would we great. Thank you :)
    Brandan Hermo and Luis Gimeno like this.
  2. media2
    Oct 16, 2014
    5
    I agree! Please add report filtering on SIP trunks.
    Simone
    Brandan Hermo likes this.
  3. Brandan Hermo
    Jul 10, 2017
    43
    9
    +1
    We need too, reports based on DDI
