Call return functionality
Discussion in '3CX Phone System - General' started by cparman, Oct 6, 2014.
  1. cparman
    Oct 6, 2014
    Hello All,
    I can't seem to find the area in the 3CX GUI where the "Call Return" functionality resides. I believe it's somewhere because when I dial "*69" on the registered phone (Polycom SoundPoint 330) I get a recording stating to "Activate call return dial 1". So when I press "1" I get a message that "You must dial a 1 or 0 when calling this number". I suppose my real question is does 3CX support "Call Return"?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    I do not think the PBX supports the function. However, some phones (Cisco as an example) have settings that accommodate the functionality of several traditional dial/feature codes.
