Call/Ring group Maximum Number of Members?
Discussion in '3CX Phone System - General' started by nobody, Feb 9, 2018.
  1. nobody
    Aug 15, 2017
    75
    Is there a limit regarding the maximum numbers of phone numbers I can assign a ring group to?
    TIA.
  2. voiptoys
    voiptoys Member
    Feb 13, 2013
    492
    81
    Nope. The inbound rule just forwards the call to the extension. It doesn't know anything about the type of extension.
  3. nobody
    Aug 15, 2017
    75
    Thank you.
    Just to make sure, I can add 500 phones into one group, and all will ring when the group is called?
  4. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    You need a 512 or 1024 SC license to ring them all simultaneously
  5. nobody
    Aug 15, 2017
    75
    Ok,
    Then there is no limit besides the number of Concurrent Calls I licensed.
    But that makes me think:
    Since 3cx is licensed by the number of simultaneous calls, why should this limit limit the number of phones in a ring group?
    Actually my numbers are much lower:
    I have 30 Phones and considering buying a Pro version with 16lines. However, I would expect that (besides setting up a call queue) it should be possible that the Phones of all 30 Agents will ring when a call comes in.
    #5 nobody, Feb 9, 2018
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @nobody
    Actually even if you have 500 agents in a ring group the polling will only use up one simultaneous call. However you should consider your ring strategy. If you select ring all and have a massive amount of extensions then it will take some time to ring all the extensions. With 30 phones you should be fine.
  7. nobody
    Aug 15, 2017
    75
    Thank you,
    That was what I expected.
    If we are on the subject regarding a larger number of Agents:
    I thought I create a "primary" ring-group with lets assume 15Members.
    Then, I use the Ring groups Number to create a BLF on the Other 15 Agents phones. These should be notified on their Phones by an optical Message (blinking light), also the numbers (or Names) of the callers waiting should appear on the phones displays, so they can decide theirselve if the call is relevant for them or not.
    I consider to buy yealink T46s or T48s phones.
    Would this be an option?
    I found out that the Yealink T4XX series have a feature like this, but i dont know If that will really work together with the 3CX phone system. I personally have only snom currently availible which have display which way to small, and Yealink W56 which dont support this feature.
    TIA
  8. YiannisH_3CX
    May 10, 2016
    4,443
    282
    Please note that you cannot assign a ring group to a blf button at least not with a supported way. You can only assign extensions and monitor whether they are busy or not.
    Perhaps someone else has a similar configuration and can help you achieve this.
