tsukraw
- Joined
- Mar 9, 2012
- Messages
- 190
- Reaction score
- 10
So have a customer with multiple locations. For this explanation we will keep it simple and just say they have 2 locations.
They are using NexVortex which has a DR function to be able to send the SIP DID to multiple IPs if the main IP is down.
Normally you would program the DIDs in the VOIP Provider and setup Source Identifications by DID to be able to route the DID to a destination.
Since they have multiple locations (9) and multiple DIDs at each location i don't want to program all those DIDs into each system. So i was thinking a catch all (*) in the DID list but 3CX doesn't allow this. Then i thought (1*) as the catch all but when doing this it caught every incoming DID even ones that were fully entered....
I know catch Calls (*) are not necessary recommended as it makes hacking easier but we have a SBC between our provider and the 3CX so we are not really worried about this. So please leave security out of any recommendations.
Does anyone have any good ideas on how to accomplish this. Im kind of at a loss of ideas on this one.
I have attached a simple diagram.
We have DID 111-111-1111 going to the Minnesota 3CX and setup as a DID and Source Identification by DID.
We have DID 222-222-2222 going to the Iowa 3CX and setup as a DID and Source Identification by DID.
If the Minnesota system is down NexVortex sends the DID 111-111-1111 over to the Iowa IP Address.
Right now the call would fail.
We need to figure out a way that any DID that is not programmed to come in one a catch all entry.
