Call Sound Volume
Discussion in '3CX Phone System - General' started by turnkey, Aug 24, 2010.
  1. turnkey
    May 9, 2009
    64
    We have a bit of an odd issue, in that calls are extremely quiet, the physical phones (Cisco SPA50's) are turned up full, but calls are still very quiet.
    Is there a way of 'centrally' turning up the volume on calls?
    Thanks,
    Mike
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Hi Mike
    Is this happening on internal calls also? i.e. Cisco --> Cisco?
    You dont have PBX Delivers audio set for the extension do you?
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    If the problem is coming for calls from a gateway more ofthen then not here are option to increase the audio coming in, a wireshark caputure may help you to realise where the low audio is coming from so that you can eliminate multiple possibilitys.
