Call stay on status if network faild
Discussion in '3CX Phone System - General' started by amygoda, Aug 20, 2007.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    2 times when net work failed the server status keep show the coonection
    (orange color)
    and the network switch show trafic
    I tried to delete booth connection and restart them and cut the power
    the problem steel
    only restart the server solve this problem
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Ya, i get that too, its a bug i think. If the users dont send the "Bye" command to server he will assume always that the connection is still going.. something to be fixed on next releases i hope :p
  3. beavis82
    Aug 20, 2007
    I've had this a few times - worryingly whenever this has happend there appears to be constant data activity between the box running 3cx and the Internet, so not only is it using up by broadband data allowance (I have a capped ADSL service) but I maybe also incurring call charges from my VOIP provider. I'm keeping a very close eye on my router's activity light after every call... I really hope this bug is fixed soon or I may have to ditch 3CX altogether! I'd hate to do that because otherwise it's excellent software.
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    there is other picture for this bug
    when you recieve a call from pstn and the caller closed before you pickup
    but any way this very good free system and promised to be the best
    I advice it for a lot
    and if some features added to it I think I'll work on selling and install the paid version
