I'm using voip.ms as my provider. Everything else seems to be working correctly. Below is a copy of the server log during the call. IP addresses and numbers have been xxxx to protect privacy.
The extension "109" is a member of a call group. I've tried changing the incoming rules to dial the extension directly with no change. Also, the rebound feature is enabled on that extension (109).
Thanks for your help. I love this feature and would like to get it working if possible.
05-Sep-2013 19:59:50.156 Leg L:46.1[Ivr] is terminated: Cause: BYE from PBX
05-Sep-2013 19:59:50.156 [CM503008]: Call(C:46): Call is terminated
05-Sep-2013 19:59:50.155 Leg L:46.2[Line:10001>>905407xxxx] is terminated: Cause: BYE from PBX
05-Sep-2013 19:59:25.270 Currently active calls - 1: [46]
05-Sep-2013 19:58:55.254 Currently active calls - 1: [46]
05-Sep-2013 19:58:25.231 Currently active calls - 1: [46]
05-Sep-2013 19:57:55.215 Currently active calls - 1: [46]
05-Sep-2013 19:57:25.192 Currently active calls - 1: [46]
05-Sep-2013 19:56:55.176 Currently active calls - 1: [46]
05-Sep-2013 19:56:25.156 Currently active calls - 1: [46]
05-Sep-2013 19:56:14.867 Leg L:45.5[Line:10001>>905407xxxx] is terminated: Cause: BYE from PBX
05-Sep-2013 19:56:14.867 [CM503008]: Call(C:45): Call is terminated
05-Sep-2013 19:56:14.864 Leg L:45.1[Line:10001<<905407xxxx] is terminated: Cause: BYE from 67.205.xx.xxx:5060
05-Sep-2013 19:56:07.723 Leg L:45.4[Ivr] is terminated: Cause: BYE from 127.0.0.1:40600
05-Sep-2013 19:56:07.521 [CM503007]: Call(C:45): Line:10001>>905407xxxx has joined, contact <sip:
[email protected]:5060>
05-Sep-2013 19:56:07.516 L:45.5[Line:10001>>905407xxxx] has joined to L:45.1[Line:10001<<905407xxxx]
05-Sep-2013 19:56:07.516 [CM505003]: Provider:[289242xxxx] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [VoIPMS/SERAST] PBX contact: [sip:
[email protected]:5060]
05-Sep-2013 19:56:07.351 [CM503025]: Call(C:45): Calling T:Line:10001>>905407xxxx@[Dev:sip:
[email protected]:5060] for L:45.1[Line:10001<<905407xxxx]
05-Sep-2013 19:56:07.162 [CM505003]: Provider:[289242xxxx] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [VoIPMS/SERAST] PBX contact: [sip:
05-Sep-2013 19:55:55.141 Currently active calls - 2: [45,46]
05-Sep-2013 19:55:47.550 [CM503007]: Call(C:46): Line:10001>>905407xxxx has joined, contact <sip:
05-Sep-2013 19:55:47.549 [CM503007]: Call(C:46): Ivr:IVRForward has joined, contact <sip:
[email protected]:40600>
05-Sep-2013 19:55:47.549 L:46.2[Line:10001>>905407xxxx] has joined to L:46.1[Ivr]
05-Sep-2013 19:55:41.021 [CM505003]: Provider:[289242xxxx] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [VoIPMS/SERAST] PBX contact: [sip:
05-Sep-2013 19:55:36.799 [CM503025]: Call(C:46): Calling T:Line:10001>>905407xxxx@[Dev:sip:
[email protected]:5060] for L:46.1[Ivr]
05-Sep-2013 19:55:36.615 [CM503027]: Call(C:46): From: Ivr:IVRForward ("289242xxxx:xxxx Cell " <sip:
[email protected]:5060>) to T:Line:10001>>905407xxxx@[Dev:sip:
05-Sep-2013 19:55:36.615 [CM503004]: Call(C:46): Route 1: from L:46.1[Ivr] to T:Line:10001>>905407xxxx@[Dev:sip:
05-Sep-2013 19:55:36.615 Line limit check: Current # of calls for line Lc:10001(@289242xxxx[<sip:
[email protected]:5060>]) is 1; limit is 4
05-Sep-2013 19:55:36.615 Call(C:46): Call from Ivr:IVRForward to 905407xxxx matches outbound rule 'Tech Outbound'
05-Sep-2013 19:55:36.615 [CM503001]: Call(C:46): Incoming call from Ivr:IVRForward to <sip:
05-Sep-2013 19:55:27.188 Leg L:45.2[Ivr] is terminated: Cause: BYE from 127.0.0.1:40600
05-Sep-2013 19:55:26.981 [CM503007]: Call(C:45): Ivr:IVRForward has joined, contact <sip:
05-Sep-2013 19:55:26.978 L:45.4[Ivr] has joined to L:45.1[Line:10001<<905407xxxx]
05-Sep-2013 19:55:26.938 Leg L:45.3[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.50.50:5090
05-Sep-2013 19:55:26.936 [CM503003]: Call(C:45): Call to <sip:
[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 192.168.50.50:5090
05-Sep-2013 19:55:26.834 [CM503025]: Call(C:45): Calling T:Ivr:IVRForward@[Dev:sip:
[email protected]:40600;rinstance=56d5b1dd4bb0c23c] for L:45.1[Line:10001<<905407xxxx]
05-Sep-2013 19:55:26.831 [CM503005]: Call(C:45): Forwarding: T:Ivr:IVRForward@[Dev:sip:
05-Sep-2013 19:55:26.831 L:45.1[Line:10001<<905407xxxx] forwards call from Extn:109 to Ivr:IVRForward based on rule Fwd[Available/NoAnsw]
05-Sep-2013 19:55:26.831 L:45.1[Line:10001<<905407xxxx] failed to reach Extn:109, reason No Answer
05-Sep-2013 19:55:25.116 Currently active calls - 1: [45]
05-Sep-2013 19:55:15.814 [CM503025]: Call(C:45): Calling T:Extn:109@[Dev:sip:
[email protected]:5090] for L:45.1[Line:10001<<905407xxxx]
05-Sep-2013 19:55:15.809 [CM503027]: Call(C:45): From: Line:10001<<905407xxxx ("289242xxxx:xxxx Cell " <sip:
[email protected]:5060>) to T:Extn:109@[Dev:sip:
05-Sep-2013 19:55:15.809 [CM503004]: Call(C:45): Route 1: from L:45.1[Line:10001<<905407xxxx] to T:Extn:109@[Dev:sip:
05-Sep-2013 19:55:15.809 [CM505003]: Provider:[289242xxxx] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [VoIPMS/SERAST] PBX contact: [sip:
05-Sep-2013 19:54:59.512 [CM503007]: Call(C:45): Ivr:804 has joined, contact <sip:
05-Sep-2013 19:54:59.509 [CM503007]: Call(C:45): Line:10001<<905407xxxx has joined, contact <sip:
05-Sep-2013 19:54:59.507 L:45.2[Ivr] has joined to L:45.1[Line:10001<<905407xxxx]
05-Sep-2013 19:54:59.356 [CM503025]: Call(C:45): Calling T:Ivr:804@[Dev:sip:
[email protected]:40600;rinstance=1bef2c33ed1929c7] for L:45.1[Line:10001<<905407xxxx]
05-Sep-2013 19:54:59.344 [CM503027]: Call(C:45): From: Line:10001<<905407xxxx ("289242xxxx:xxxx Cell " <sip:
[email protected]:5060>) to T:Ivr:804@[Dev:sip:
05-Sep-2013 19:54:59.344 [CM503004]: Call(C:45): Route 1: from L:45.1[Line:10001<<905407xxxx] to T:Ivr:804@[Dev:sip:
05-Sep-2013 19:54:59.344 [CM505003]: Provider:[289242xxxx] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [VoIPMS/SERAST] PBX contact: [sip:
05-Sep-2013 19:54:59.339 [CM503001]: Call(C:45): Incoming call from Line:10001<<905407xxxx to <sip:
