call to clic
Discussion in 'Windows' started by tourainereseau, Feb 16, 2016.
  1. tourainereseau
    Dec 20, 2013
    it would with a call to click that automatically integrates in web pages , such as skype
    thank you
  2. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    Sounds like you are describing the WebRTC feature of 3CX.
    Allen
  3. dschmuck
    Feb 16, 2016
    On MacOS we are deadly missing a feature to call a number from any app an from the contacts app.
    What we look for:
    Selecting or right click a phone number anywhere in a document or on a website (browser) -> and dial via the 3cx softphone
  4. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    This is already available in 3CX using the 'tel' protocol, more information for which can be found here:
    http://www.3cx.com/blog/voip-howto/tel-protocol-3cxphone/
    Note that using this feature does require the 3CX Phone System to be using a Pro License, not Standard.
    Given this this topic is being moved back to "3CXPhone for Windows" for further discussion.
  5. NickD_3CX
    Jun 2, 2014
    1,379
    84
    In MacOS I believe the 'tel' protocol can also be used, you might though have to open FaceTime and in the Settings change the default app that 'tel' links launch and change that to 3CXPhone. After doing this if I recall you must restart it.
  6. dschmuck
    Feb 16, 2016
    I can select 3CX Phone in Facetime on Mac OS. It does not show any difference to me. It does not dial via 3CX and after restarting facetime the setting is always back to facetime. I use MacOS 10.11.6. and 3CX Softphone 14.0.0.171:
