call to PBX no audio
Discussion in '3CX Phone System - General' started by Widerawo, Jun 18, 2011.
  1. Widerawo
    Jun 18, 2011
    I'm new here!
    And I need some help.
    I have setup the 3cx PBX V10+sp1.
    The server is standing inside DMZ zone.
    On the Firewall I have forwarded tcp and udp port from port 4000-2000.
    I have configured one voip provider. (3StarsNet)
    And one extension (101) what is connect with a Grandstream (HT503) to my network.
    When I call with my mobile to my 3Starsnet number. It's ring
    And I can speak an listen on the phone what is connected to my system perfect.
    But on my mobile I can't hear nothing.
    What I need to do...?
    Please help
    Kind regards,
    Wolf
  2. Widerawo
    Jun 18, 2011
    It' not port 4000-2000 but
    4000-20000
    Kind regards
    Wolf
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, from the 3CX Console, can you go to >> Settings / Firewall Checker and run it and post the output back here for us to look at?
