Solved Call to Twillio fails
Discussion in '3CX Phone System - General' started by gigaboy, Apr 4, 2018.
  1. gigaboy
    Jul 6, 2016
    7
    I got inbound calls to work, outbound throws these logs:
    04/04/2018 3:39:35 PM - Exception: ParseException ../../rutil/ParseBuffer.hxx:230, Parse failed unexpected eof in context: 6504894546 ^ @ ../../rutil/ParseBuffer.hxx:230
    And
    04/04/2018 3:39:35 PM - Call to T:Line:10000>>+16504894546@[Dev:sip:10000@udll01.pstn.us1.twilio.com:5060] from L:14.1[Extn:00] failed, cause: Cause: 403 Forbidden/INVITE from 54.172.60.0:5060
    Note that the IP shown is Twilio's Gateway in Virginia.
    Here's what I've done:
    1. Create E164 Outbound rules as per: https://www.3cx.com/community/threads/outbound-calls-not-working-twilio.54708/
    2. Turned off E164 in the Settings Area
    3. In Twilio, I have Access control list set with the ISP supplied IP. Also have Credentials list with the username / password of the 3CX system set.
    How can I solve this?
    Thanks. Mark
  2. gigaboy
    Jul 6, 2016
    7
    I got this to work by removing the Credentials list and retesting. Calling was successful.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    3,520
    240
    Glad to see that issue has been resolved and thank you for sharing your solution.
